[Qgis-user] Atlas by year
Marco Antônio Ferreira Pedrosa
marcomottim at gmail.com
Tue Mar 26 05:43:12 PDT 2019
Hi Alexandre,
It worked perfectly! As you said:
1) I made a unique list from the years and generate a new feature. Then
used it as the coverage layer for atlas.
2) For each symboloy (rule-based):
(@atlas_pagename = "Year") AND ("Quality" = 'Excelent')
(@atlas_pagename = "Year" ) AND ("Quality" = 'Good')
so on...
As you see I changed it a little bit, so I can use the "current" year from
Atlas.
Tnks a lot!
P.S: PORTUGAL CARALHO!!!! (sou Brasileiro haha)
Marcão
Em seg, 25 de mar de 2019 às 20:58, Alexandre Neto <senhor.neto at gmail.com>
escreveu:
> You need to create a layer, with a column called year, with each year in a
> row. The layer does not need to have a geometry. Use that layer as the
> For the layer you want to filter by year, create a rule-based symbology,
> and use the following rule/expression:
> attribute(@atlasfeature, 'yea
> r') = "year"
> This compares the current atlas feature field year, to the layer year
> column, and renders the features only if the years match.
> Hope it helps.
> Alexandre Neto
> A seg, 25/03/2019, 13:50, Marco Antônio Ferreira Pedrosa <
> marcomottim at gmail.com> escreveu:
>> Hi all,
>> Sorry if s a silly question!
>> How to generate an atlas by a value in the attibute table? (i.e: Year).
>> QGIS Atlas would generate one map for each attribute value but not group by
>> year.
>> For each year, I want to show the features with a categorized symbology
>> (same for all years, but I want to show just the features from that year).
>> tnks in advance!
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190326/19db79b2/attachment.html>
