[Qgis-user] problem in clipping
Raymond Nijssen
r.nijssen at terglobo.nl
Thu Mar 28 04:19:39 PDT 2019
Or you can try the buffer tool with a buffer distance of 0.
Good luck!
On 28-03-19 12:25, Wouter Impens wrote:
> Hi Boaz,
> You can use the processing tool 'repair geometry' to fix the geometry.
> regards
> Wouter
> Op do 28 mrt. 2019 om 09:48 schreef Boaz Bar Ilan <boazprosie at gmail.com
> <mailto:boazprosie at gmail.com>>:
> im trying to clip and get this message
> Feature (6727) has invalid geometry. Please fix the geometry or
> change the Processing setting to the "Ignore invalid input features"
> option.
> Execution failed after 4.02 seconds
> im usinf 3.4 version
> can you help ?
> thanks
> boaz
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
