[Qgis-user] Dereference plugin not working
Bertrand Houdusse bertrandhoudusse at gmail.com
Wed May 1 14:26:17 PDT 2019
Hi Damien,
If this is related to the classic problem of the Georeferencer's
disapearing window (almost everi time due to the use of dual screen), and
if you are on Windows, I recommend you to test this procedure :
- start Qgis
- click on the georeferencer button
- if the window doesn't appear, and if Qgis' main window looses focus, that
means the focus has gone to the georeferencer's window. So you just have to
immediatly click this combination :  Windows logo key + Left Arrow (or  WIN
+ RIGHT ARROW) ; this is the shortcut to maximize the active window to the
left (or right) side of the screen (link
<https://support.microsoft.com/en-us/help/12445/windows-keyboard-shortcuts>
If the georeferencer's windows doesn't show up, you can click the
combination several times until success
This usually works fine for many people on Windows (WIN 7 to 10). I don't
know if there's something similar in Linux or Mac
If this solution doesn't solve your problem, that may be because the
georeferencer's window is reduced in a bottom corner of your screen
(Windows OS again) : you can take a close look at the two corners and
search for this reduced window, that can be very small.
Good luck
Bertrand
Le mer. 1 mai 2019 à 04:43, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
a écrit :
> Hi,
> Could this be a change in QGIS 3.6?
> https://qgis.org/en/site/forusers/visualchangelog36/index.html#feature-new-option-to-avoid-minimizing-georeferencer-when-adding-points
> Le 30 avr. 2019 à 21:16, damien stephens <damien.stephens at gmail.com> a
> écrit :
> Hi.
> I am on qgis 3.6.
> I have been using the referencing plugin for a while with no dramas, but
> now when I click on the tool button in the raster menu, qgis loses focus,
> but the georeferencer window does not appear.
> Have Googled an answer but they are all for qgis v2 and the registry keys
> they recommend changing  are different.
> My qgis 2.18 copy runs georeferencer fine.
> Any help much appreciated.
> Damien
> On Mon, 29 Apr. 2019, 01:35 Tulika Biswas, <teentulika at gmail.com> wrote:
>> I have an issue with using the georeferencer.My problem is after adding
>> co ordinates to the map and giving the transformation settings.. I am
>> running the georeferencing option.. Then it is being displayed on the
>> screen as
>> "Failed to compute GCP points." and the map is also not being shown in
>> the qgis interface..
>> Plz  help.. Its very urgent..
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190501/99fbfeff/attachment.html>
