[Qgis-user] error message when opening a project
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sun May 5 16:02:10 PDT 2019
I have no idea what this error is but my first reaction would be to uninstall QGIS and reinstall QGIS.  If that does not help, please add what version of QGIS you have, what installer you used and what operating system you are on.  I would add what version the projects are done with.  You could also disable all plugins that could be at the root of the problem. That would help others figure things out.
Good luck,
Nicolas
> Le 5 mai 2019 à 10:20, Celso Catelani <cscatelani at gmail.com> a écrit :
> Hi,
> I'm receiving an error message in all projects i try to open, saying the follow:
> type object 'Qgis' has no attribute 'WkbUnknown'
> Traceback (most recent call last):
>   File "C:/Users/Celso/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py", line 702, in update_local_layers
>     self.update_local_data_sources(local_layers,  local_raster_layers)
>   File "C:/Users/Celso/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py", line 775, in update_local_data_sources
>     "Unsupported geometry type '{type}' in layer '{layer}'").format(type=self.__wkbTypeString(wkbType), layer=layers[0].name()))
>   File "C:/Users/Celso/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py", line 808, in __wkbTypeString
>     if wkbType == Qgis.WkbUnknown:
> AttributeError: type object 'Qgis' has no attribute 'WkbUnknown'
> Please, may someone help me about this?
> Tanks a lot!!!!
>  Celso S. Catelani
> 	Livre de vírus. www.avast.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190505/83b83288/attachment.html>
