[Qgis-user] Cartograms in QGIS 3
Jonathan Moules jonathan-lists at lightpear.com
Sun May 12 15:11:27 PDT 2019
In case anyone is curious and comes across this in the future, it turns
out that the number of iterations that was necessary using the
Cartogram3 plugin was on the order of 250! This is far more than
tutorials and the docs recommend ( <= 10).
On 2019-04-21 13:24, Jonathan Moules wrote:
> Hi List,
> Does anyone have any suggestions for how to simply create a Cartogram
> in QGIS 3? I've tried the Cartogram3 plugin
> (https://github.com/austromorph/cartogram3) but the output is visually
> near-identical to the input, even up to 50 iterations.
> The data is a (geopackage) world map of countries with integer values
> of 0 to 230,000.
> I've tried googling around but many of the results are for QGIS 2.
> Thanks,
> Jonathan
> Qgis-user mailing list
