[Qgis-user] WFS layer filter - fails to filter on name or abstract
Jonathan Moules jonathan-lists at lightpear.com
Sun May 12 16:12:19 PDT 2019
Hi Lars,
Confirmed (3.4.3) - personally I'd consider it "suboptimal behaviour".
Whether it's a bug depends on the originally desired behaviour. It
should definitely be possible to search more than just the title.
Especially as many layers don't have titles due to setups ("Name" is the
only mandatory field).
I've opened it as a bug here: https://issues.qgis.org/issues/22053 -
also applies to ArcGIS MapServer
Cheers,
Jonathan
On 2019-05-09 09:21, Lars I. Nielsen, LIFA A/S wrote:
> Hi list.
> When I connect to a WFS source, I get a list of layers to open. The
> list has 3 columns: Title, Name and Abstract. Most have values in all
> three.
> If the list is long, I want to limit it by a filter, which I specify
> in the “Filter” text box. The tooltip for this box says, that it’ll
> filter on all/any of the three columns.
> But if I enter a string, that only occurs in the name column, but not
> in the title column, it shows no layers. The same happens with the
> abstract column.
> It seems that the dialog only filter wrt. the title column. This must
> be a bug, right ?
> Using QGis 3.4.5 (Danish)
> Med venlig hilsen
> GIS-konsulent, FME Certified Professional
> Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\284x82-Images-Get-L749-l3.gif
> *T*
> 6313 6800
> lin at lifa.dk
> *D*
> 6313 6849
> *W*
> www.lifa.dk <http://www.lifa.dk>
> *M*
> 2492 4866
> *CVR*
> 20937289
> *Vi tilbyder interne og eksterne kurser. Du kan finde mere information
> i vores **kursuskalender <https://www.lifa.dk/kursuskalender>*
> Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-Images-Get-L749-l8.png
> <https://www.linkedin.com/company/lifa-a-s/>
> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190513/2370890c/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190513/2370890c/attachment.gif>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190513/2370890c/attachment.png>
