[Qgis-user] Error saving/exporting data with many attributes
Stefan Keller sfkeller at gmail.com
Tue May 14 14:13:25 PDT 2019
Can't you delete such attributes with same (lower case) name - and
their contents - before making the layer permanent / exporting it?
:Stefan
Am Di., 12. März 2019 um 16:36 Uhr schrieb <b.j.kobben at utwente.nl>:
> Thanks for the info Patrick. I totally agree this is unwise, but the OSM (OpenStreetMap) dataset I am working with unfortunately comes with some of these (unwisely chosen) attribute tags :-(
> So indeed inconsistency in how that 's handled is annoying. In defence of QGIS programmers, I think it's because the different import/export formats have different rules and defaults...
> yours,
> Barend Köbben
> On 12/03/2019, 11:45, "Qgis-user on behalf of Patrick Dunford" <qgis-user-bounces at lists.osgeo.org on behalf of enzedrailmaps at gmail.com> wrote:
> Case sensitive names (from experience) are handled inconsistently within the Qgis software. It would be unwise to have two different columns where the names are only distinguished by case, unless the developers choose to address these issues in future.
> On 12/03/19 12:20 AM, b.j.kobben at utwente.nl wrote:
> To answer my own question: the problem is actually not the amount of attributes, but the fact that there are (2x) attributes columns with the same name (although they are different if you consider case sensitivity). Apparently GeoJSON is the only format that allows differentiating column names by upper/lowercase....
> yours,
> Barend Köbben
> On 11/03/2019, 11:55, "Qgis-user on behalf of b.j.kobben at utwente.nl" <qgis-user-bounces at lists.osgeo.org on behalf of b.j.kobben at utwente.nl> wrote:
> Hi all,
> I have a problem that (I think) comes down to a limit in the amount of attributes per object the QGIS exporting tools can handle.  Case in hand:
> 1) Import OSM data Points with many attributes (OSM tags), using QuickOSM – works
> 2) Temporary layer in QGIS is displayed -  seems fine
> 3) "Make Permanent" or "Export As..." fails on all file formats (except GeoJSON!). Error message is (for the GeoPackage case):
> Export to vector file failed.
> Error: Feature write errors:
> Feature creation error (OGR error: sqlite3_exec(CREATE TABLE "test" ( "fid" INTEGER PRIMARY KEY AUTOINCREMENT NOT NULL, "geom" POINT, "full_id" TEXT(255), "osm_id" TEXT(255), "osm_type" TEXT(255), "highway" TEXT(255),
> ... many more attributes...
> "safe_place:school" TEXT(255), "safe_place:mosque" TEXT(255))) failed: duplicate column name: Operational_status)
> Feature creation error (OGR error: failed to prepare SQL: INSERT INTO "test" ( "geom", "full_id", "osm_id", "osm_type", "highway", "name",
> ... again the same many more attributes...
> "safe_place:school", "safe_place:mosque") VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?))
> This happens even when I have only 2 features (see attached test file). The workaraound is to use GeoJSON, bacuse for some reason that one works, but in normal case I have 1000s of points instead of two, and then a GeoJSON file becomes very large and unwieldy...
> Any ideas if this is a bug or a limit in the actual formats such as GeoPackage...?
> yours,
> Barend Köbben
> Senior Lecturer – ITC-University of Twente & ATLAS
> PO Box 217, 7500 AE Enschede (Netherlands)
> ITC Building (room 1-065)
> @barendkobben
> +31-(0)53 4874 253
> Qgis-user mailing list
