[Qgis-user] Unable to launch QGIS with X Forwarding - Can Not make qgis.db private copy
Amedeo Fadini amefad at gmail.com
Sun May 19 07:58:49 PDT 2019
Hi Jurgen,
Thank you so much, solved.
Il giorno dom 19 mag 2019 alle ore 13:00 Jürgen E. Fischer <jef at norbit.de>
ha scritto:
> Hi Amedeo,
> There's no .qgis3 anymore - the user profiles are in
> ~/.local/share/QGIS/QGIS3/profiles
Yes, I've found this information from Salvatore Fiandaca in the
meanwhile....
I have found only the user profile under /root and not under
/home/<myuser>...
It works if I connect with ssh -X root@<myserver>
Copying profile in my home  let me open as an unprivileged user, even if
gives me an alert about updating private db (I'll check permission)
Should I copy or link the profile for other users?
Amedeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190519/c4dbe9a7/attachment.html>
