[Qgis-user] Fw: KMZ
Lukas Sadler lukas_sadler at yahoo.com
Sun May 19 19:58:16 PDT 2019
another question, pretty please
how does one export a clip of a base map layer as a reference jpeg/Tiff
I've tried 'clip raster by extent' but when i run it it says 'layers were not correctly generated'
   ----- Forwarded Message ----- From: Lukas Sadler <lukas_sadler at yahoo.com>To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>; Brent Wood <brent.wood at niwa.co.nz>Sent: Monday, May 20, 2019, 2:39:05 PM GMT+12Subject: Fw: [Qgis-user] KMZ
 Okay
I got it to work
project and base map layer needs to be in WGS 84/Pseudo-Mercator with KMZ file set as WSG 84
   ----- Forwarded Message ----- From: Lukas Sadler <lukas_sadler at yahoo.com>To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>; Brent Wood <Brent.Wood at niwa.co.nz>Sent: Monday, May 20, 2019, 2:26:16 PM GMT+12Subject: Re: [Qgis-user] KMZ
 thanks guys
but still not doing the trick
I've got everything in 4326 and the KMZ is still not sitting in the correct location
the location is in New Zealnd but if i use 4326 it looks like it sits on the opposite longitude
    On Monday, May 20, 2019, 2:14:17 PM GMT+12, Brent Wood <Brent.Wood at niwa.co.nz> wrote:
I think KMZ supports lat/long coords only... Google doesn't really understand projections...
Make sure your KMZ layer has EPSG:4326 as its projection
HTH
Brent Wood
Programme leader: Environmental Information Delivery
NIWA
DDI:  +64 (4) 3860529
| Brent Wood |
| Principal Technician - GIS and Spatial Data Management |
| Programme Leader - Environmental Information Delivery |
| T+64-4-386-0529 |   |  |
| National Institute of Water & Atmospheric Research Ltd (NIWA) |
| 301 Evans Bay Parade, Greta Point, Wellington |
| Connect with NIWA:niwa.co.nz Facebook Twitter LinkedIn Instagram |
| To ensure compliance with legal requirements and to maintain cyber security standards, NIWA's IT systems are subject to ongoing monitoring, activity logging and auditing. This monitoring and auditing service may be provided by third parties. Such third parties can access information transmitted to, processed by and stored on NIWA's IT systems. |
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Lukas Sadler <lukas_sadler at yahoo.com>
Sent: Monday, May 20, 2019 13:45
Subject: [Qgis-user] KMZ Hi,
I've tried importing KMZ files from google earth into a project on QGIS (3.6.3 Noosa) but the files don't project in the same location even if i set it to the project's CRS
what should i do to have the KMZ files projecting in the correct location
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/7a3d406b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/7a3d406b/attachment-0001.png>
