[Qgis-user] las files
Andreas Neumann a.neumann at carto.net
Mon May 20 02:34:21 PDT 2019
Hi Tony,
Basically you have two options for using/converting LAS/LAZ files in QGIS:
* LasTools (commercial, requires license), integrated in QGIS processing
toolbox
* PDAL (OpenSource), not yet properly integrated in QGIS processing toolbox
If all you need is a LAS/LAZ viewer there is also plas.io where you can
load and view a LAS/LATZ directly in a modern web browser with WebGL
support.
If you want to go the "free" route you'll have to use PDAL outside of
QGIS (on the command-line) and convert them to GeoTIFF files. Have a
look at the PLAS tutorials at https://pdal.io/tutorial/index.html
There are very loose, not yet concrete, plans to better integrate PDAL
in the QGIS processing toolbox, and there is even a QGIS plugin for that
in the very early stages. If you are adventurous you could try if it
works for you.
Greetings,
Andreas
Am 20.05.19 um 09:10 schrieb Tony Shepherd (FarmMaps NZ):
> Hi All
> I'm new to QGIS after using MapInfo for more years than I dare to
> admit and finding QGIS great.  I’m making full use of the 3D features
> as I work mainly in the forestry industry and as they say, a picture
> says a thousand words, particularly when showing topography.  My
> question is, I am trying to find a way of converting some LiDar data
> that I have (las files) to something that QGis can use when creating
> 3D views.  Currently I’m using tif DEM files, so can anyone point me
> in the right direction to creating a dem from las files?  I can't see
> any plugins so wonder how others are achieving this?
> Cheers
> Tony
> *Tony Shepherd**|*GeoSpatial
> Ph 027 435 6193 *|*  E tony at farmmaps.nz
> FarmMaps NZ, 3 Kerwood Place, Gore 9740
> FM_logo1_small (Custom)
> ** <http://tonyshepherd8.wixsite.com/home>**
> <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>**
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/c0bbc648/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/c0bbc648/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/c0bbc648/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/c0bbc648/attachment-0003.png>
