[Qgis-user] Layer panel docking problem
Stefan Giese Stefan.Giese at wheregroup.com
Mon May 20 03:07:17 PDT 2019
I think just double click in the header of the layer panel will dock it
again, see this animated gif:
https://drive.google.com/file/d/1_pxBEFx9J5ny1cCyk8XlxWl5xKe81bSR/view?usp=sharing
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 20.05.2019 um 11:39 schrieb Karl Magnus Jönsson:
> Hi!
> The Layer Panel should be dockable. Could be a little bit tricky. Try
> several times.
> *Karl-Magnus*
> *Från:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *För
> *Susan Iremonger
> *Skickat:* den 19 maj 2019 16:32
> *Till:* qgis-user
> *Ämne:* [Qgis-user] Layer panel docking problem
> Hi All,
> Please help me with this: I am using QGIS 3.4. Somehow I un-docked my
> Layer Panel and now it just floats over the display, which now takes
> up all the space on my screen. So the Layer Panel obscures the left
> side of the display of the map/data. I have tried moving the panel all
> the way to the left to see if it will dock again for me, without joy.
> I have also tried the same thing moving it to the right. I have even
> uninstalled and installed the program again, and it has the same problem.
> Before this happened I think I clicked a little icon next to the "x"
> at the right hand upper corner of the Layer Panel . This has
> disappeared now but it might have had somehting to do with the
> undocking of the panel. Any help much appreciated.
> Susan.
> Carra Lodge
> Pound road
> Carrabaun
> Westport
> Co. Mayo F28 VK58
> Ireland
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/54b25abd/attachment.html>
