[Qgis-user] Fw: KMZ
Lukas Sadler lukas_sadler at yahoo.com
Mon May 20 15:27:59 PDT 2019
brilliant, it worked thanks a mil
    On Monday, May 20, 2019, 6:28:35 PM GMT+12, Stefan Giese <Stefan.Giese at wheregroup.com> wrote:
from the menu just use Project -> Import/Export -> Export Map to Image
and your map will be saved as an image (tif, jpg, png...) with or without a world file (for georeference)
 Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
------------------------------- Am 20.05.2019 um 04:58 schrieb Lukas Sadler:
  another question, pretty please
  how does one export a clip of a base map layer as a reference jpeg/Tiff
  I've tried 'clip raster by extent' but when i run it it says 'layers were not correctly generated'
     ----- Forwarded Message ----- From: Lukas Sadler <lukas_sadler at yahoo.com> To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>; Brent Wood <brent.wood at niwa.co.nz> Sent: Monday, May 20, 2019, 2:39:05 PM GMT+12 Subject: Fw: [Qgis-user] KMZ
       Okay
  I got it to work
  project and base map layer needs to be in WGS 84/Pseudo-Mercator with KMZ file set as WSG 84
      ----- Forwarded Message ----- From: Lukas Sadler <lukas_sadler at yahoo.com> To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>; Brent Wood <Brent.Wood at niwa.co.nz> Sent: Monday, May 20, 2019, 2:26:16 PM GMT+12 Subject: Re: [Qgis-user] KMZ
       thanks guys
  but still not doing the trick
  I've got everything in 4326 and the KMZ is still not sitting in the correct location
  the location is in New Zealnd but if i use 4326 it looks like it sits on the opposite longitude
       On Monday, May 20, 2019, 2:14:17 PM GMT+12, Brent Wood <Brent.Wood at niwa.co.nz> wrote:
I think KMZ supports lat/long coords only... Google doesn't really understand  projections...
Make sure your KMZ layer has EPSG:4326 as its projection
HTH
    Brent Wood
 Programme leader: Environmental Information Delivery
 NIWA
 DDI:  +64 (4) 3860529
| Brent Wood |
| Principal Technician - GIS and  Spatial Data Management |
| Programme Leader - Environmental  Information Delivery |
| T +64-4-386-0529 |   |
| National Institute of Water & Atmospheric Research Ltd  (NIWA) |
| 301 Evans Bay Parade, Greta Point,  Wellington |
| Connect with NIWA: niwa.co.nz Facebook Twitter LinkedIn Instagram |
| To ensure compliance  with legal requirements and to  maintain cyber security standards, NIWA's IT systems are  subject to ongoing monitoring,  activity logging and  auditing. This monitoring and auditing  service may be provided by  third parties. Such third parties can  access information transmitted to, processed by and stored  on NIWA's IT systems. |
    From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Lukas Sadler <lukas_sadler at yahoo.com>
 Sent: Monday, May 20, 2019 13:45
 Subject: [Qgis-user] KMZ      Hi,
  I've tried importing KMZ files from  google earth into a project on QGIS (3.6.3 Noosa) but the files don't project in the  same location even if i set it to the project's CRS
  what should i do to have the KMZ files  projecting in the correct location
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/58ff028e/attachment.html>
