[Qgis-user] CRS / reprojection problems
Alexandre Neto senhor.neto at gmail.com
Mon May 20 23:39:50 PDT 2019
Haven't had any problems with any of the versions. I would dare to guess
that the problem lies on the data. Can you please share some sample data?
A ter, 21/05/2019, 02:53, Matt Boyd <mattslists at gmail.com> escreveu:
> Hi QGISers,
> I'm having an issue with reprojecting things in QGIS.
> Installer OSGEO64W
> Latest version and LTS both have same issue.
> Issue:
> reprojection just isn't working. If I load a data set with decimal degrees
> and another with a projected coordinate system the data (points / lines /
> polygons) will only display if the basemap is in the same projection system.
> This is happening across 2 PCs, (windows10) and the LTS and latest
> versions of QGIS. Has anyone got some troubleshooting tips?
> Thanks
> Matt
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190521/d729363a/attachment.html>
