[Qgis-user] QGIS 6.3 for macOS 10.14.5 : HELP
Ramon Andinach custard at westnet.com.au
Tue May 21 16:43:12 PDT 2019
Hi Nuno,
You need to set some environmental variables, so that the GDAL binaries can be found.
William provides a nice step by step in file Read Me.txt
If you’ve already deleted the dmg I’ll paste it into a reply, but you should read Read Me.txt because it contains other useful bits of information besides the answer to your question.
Regards,
Ramon.
> On 22 May 2019, at 07:14, Nuno Manuel de Figueiredo de Santos Loureiro <nlourei at ualg.pt> wrote:
> Hi all,
> I'm a very regular (happy) user of QGIS 2.18.23.
> Recently I installed QGIS 6.3.2 on my Mac with macOS 10.14.5.
> Several tasks are running very well but when I tried to merge a few rasters I was not able to do that and I received the following message:
> GDAL command output:
> /bin/sh: gdal_merge.py: command not found
> Also, when I tried to clip a raster using a mask layer I was not able to do that and I received the following message:
> /bin/sh: gdalwarp: command not found
> What is missing or wrong?
> Can somebody help me with some tips to fix this issue?
> Many thanks in advance,
> Nuno
> -x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-
> Nuno de Santos Loureiro (PhD)
> Faculdade de Ciências e Tecnologia - DCTMA - Ed. 8
> Universidade do Algarve
> Campus de Gambelas
> 8005-139 FARO   (Portugal)
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190522/fbe365d9/attachment.html>
