[Qgis-user] format of timestamps
Christoph Jung jagodki.cj at gmail.com
Wed May 22 00:09:27 PDT 2019
Hi Matthias,
thank you for the hint, it works very well.
Sincerely,
Christoph
> Am 22.05.2019 um 08:51 schrieb Matthias Kuhn <matthias at opengis.ch>:
> Hi Christoph,
> On export you can also choose in the field export options to use the display string (Check "Replace with displayed value" for this field).
> In the layer properties -> attributes form of your layer it's possible to define how QGIS will display and format your date, you might possibly want to tune something in there too.
> I hope that helps
> Matthias
> On 5/22/19 8:45 AM, Christoph Jung wrote:
>> Hello everyone,
>> I am a bit confused about dates/timestamps in QGIS. I created a column in PostGIS to store timestamps in iso8601 format. If I load the table into QGIS and open the attribute table, the timestamp will be shown like in pgAdmin:
>> <Bildschirmfoto 2019-05-21 um 18.40.18.png>
>>  Thats all fine. But when I export the table into GeoJSON (right click on the layer - export), the format of the timestamp changes a bit:
>> <Bildschirmfoto 2019-05-21 um 18.40.37.png>
>> I know that iso8601 offers different writings of the timestamps and both should follow iso8601. But nonetheless the characters are differing. Is it a general „problem“, did anybody noticed it before?
>> Sincerely,
>> Christoph
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190522/2f4ca54c/attachment.html>
