[Qgis-user] Raster calculator
Raymond Nijssen r.nijssen at terglobo.nl
Thu May 23 13:02:03 PDT 2019
Hi Jocelyn,
Sorry for not knowing the entire answer, but here are some steps.
1. Select all cells that are not white using the Raster Calculator:
"test at 1" != 255 or "test at 2" != 255 or "test at 3" != 255
2. Set all 0 values to nodata with GRASS r.null
3. This is where I'm stuck too. :( You would like to multiply your input
raster with the output of step 2 now. But I don't know how to do this in
a way keeping all 3 bands in the output. (I tried the Raster Calculator,
the r.mask.rast from GRASS and Raster Masking form SAGA with no luck.)
Hope someone else here can help on this?
Regards,
Raymond
On 23-05-19 15:45, Jocelyn Le Baut wrote:
> Hello everybody,
> I have a problem to use the raster calculator. Some pixels of my geotiff
> file have the value 255 on the band 1, 2 and 3. I want to replace the
> value by 0 on the band 1, 2 and 3 for these pixels.
> I have try with this formula but it's not look good :
> ("test at 1" != 255)+("test at 2" != 255)+("test at 3" != 255) * "test"
> Thanks a lot for the help,
> Jocelyn
> Qgis-user mailing list
