[Qgis-user] Rogue start menu shortcut
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Fri May 24 01:11:50 PDT 2019
It turns out that it has already been reported as a bug but I can't see how to upvote it or add details of my install version etc to the bug report.
See Bug report #20890
Is anyone on this group in the development groups and able to tell me the status of this bug report? Has it even been read and is it really not a quick fix? Would I be correct in thinking there needs to be a switch added to a function in the winToast dependency to fix it?
Thanks,
Paul
-----Original Message-----
Sent: 24 May 2019 08:56
To: qgis-user at lists.osgeo.org
Subject: Re: Rogue start menu shortcut (Fernando M. Roxo da Motta)
This is nothing to do with the recently used program settings. Firstly, I don't have that setting enabled anyway and secondly those settings show icons at the top of the start menu but they don't create a physical shortcut file in the start menu folder structure.
This is much more likely to be a bug in the application as I'm almost 100% certain that it is QGIS creating the file and not Windows.
Given this is a user group I might just raise it as a bug and see if any of the developers have noticed it as well.
Thanks,
Paul
Message: 1
Date: Thu, 23 May 2019 15:35:38 -0300
From: "Fernando M. Roxo da Motta" <petro at roxo.org>
Subject: Re: [Qgis-user] Rogue start menu shortcut
Message-ID: <20190523153538.597c7e9c at cabore.cwbpr.rx>
Content-Type: text/plain; charset=UTF-8
On Thu, 23 May 2019 11:43:18 +0000, Paul Wittle <paul.wittle at dorsetcouncil.gov.uk> wrote:
  I am not a Windows user, but I know that there is a configuration to
show recently used programs in start menu.   I think it can be
disabled, if one use the procedure to activate and simply uncheck the option.
See:
https://answers.microsoft.com/en-us/windows/forum/windows_10-start/view-recently-used-programs-in-start-menu-in/bdb1e28b-31f6-460d-9714-82c00c5e0f01
 HTH
> Hi,
> Yes it is Windows 10 and definitely nothing to do with the installer.
> The closest I came to tracking it down was that the wintoast module
> creates a parameter storing a path which is almost right (it actually
> writes to the user profile but other than that it is the same path)
> and it also creates a parameter for the file extension *.lnk.
> I don’t think it is anything to do with Windows itself as I’m not
> aware of any other application which does this; it appears to be
> creating the link as part of the load procedures.
> Icons do appear in the recently used section automatically but this is
> creating a physical file with the extension *.lnk and as far as I can
> tell; wintoast is the only bit of code which is aimed at Windows users
> and has the concept of a *.lnk file (shortcut).
> Paul
> From: Alexandre Neto <senhor.neto at gmail.com>
> Sent: 23 May 2019 12:34
> To: Paul Wittle <paul.wittle at dorsetcouncil.gov.uk>
> Cc: qgis-user at lists.osgeo.org
> Hi Paul,
> Are you using Windows 10? I have seen that happen on a Windows 10 VM.
> The good part is that it's not related to QGIS installer, it's
> something Windows creates (like a recently used program). The bad part
> is that I was not able to avoid it... :-(
> Cheers,
> Alex
> On Thu, May 23, 2019 at 12:13 PM Paul Wittle
> <paul.wittle at dorsetcouncil.gov.uk<mailto:paul.wittle at dorsetcouncil.gov
> .uk>>
> wrote: Hi,
> My install of QGIS 3 (LTR) keeps adding a shortcut to the start menu
> every time I load the application. I can literally delete the shortcut
> then open QGIS and watch it create the icon again.
> Does anyone know how to stop it doing this; it is frankly just
> annoying when applications change the start menu on load rather than
> keeping that short of thing to the installer?
> I already have the shortcuts I need so this is just adding back a
> duplicate entry I can’t remove.
> Thanks,
> Paul
> This e-mail and any files transmitted with it are intended solely for
> the use of the individual or entity to whom they are addressed. It may
> contain unclassified but sensitive or protectively marked material and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All
> traffic may be subject to recording and/or monitoring in accordance
> with relevant legislation. Any views expressed in this message are
> those of the individual sender, except where the sender specifies and
> with authority, states them to be the views of Dorset Council. Dorset
> Council does not accept service of documents by fax or other
> electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its
> attachments whether encoded, encrypted or otherwise supplied are free
> from computer viruses, Dorset Council accepts no liability in respect
> of any loss, cost, damage or expense suffered as a result of accessing
> this message or any of its attachments. For information on how Dorset
> Council processes your information, please see
> www.dorsetcouncil.gov.uk/416433<http://www.dorsetcouncil.gov.uk/416433
> > _______________________________________________ Qgis-user mailing
> list Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org> List
> info: https://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
> https://lists.osgeo.org/mailman/listinfo/qgis-user This e-mail and any
> files transmitted with it are intended solely for the use of the
> individual or entity to whom they are addressed. It may contain
> unclassified but sensitive or protectively marked material and should
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
                PU5RXO                                  | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
Message: 2
Date: Thu, 23 May 2019 15:53:39 -0300
Message-ID: <20190523155339.40ff09b6 at cabore.cwbpr.rx>
On Thu, 23 May 2019 15:35:38 -0300, "Fernando M. Roxo da Motta"
<petro at roxo.org> wrote:
  It seems that it can be reached in the config>customization>start.
> option.
> See:
> 0c5e0f01
>  HTH
> > Hi,
> > installer. The closest I came to tracking it down was that the
> > wintoast module creates a parameter storing a path which is almost
> > right (it actually writes to the user profile but other than that it
> > is the same path) and it also creates a parameter for the file
> > extension *.lnk.
> > is creating a physical file with the extension *.lnk and as far as I
> > can tell; wintoast is the only bit of code which is aimed at Windows
> > users and has the concept of a *.lnk file (shortcut).
> > Paul
> > Hi Paul,
> > VM. The good part is that it's not related to QGIS installer, it's
> > part is that I was not able to avoid it... :-(
> > Cheers,
> > Alex
> > ov.uk>>
> > wrote: Hi,
> > shortcut then open QGIS and watch it create the icon again.
> > Thanks,
> > Paul
> > for the use of the individual or entity to whom they are addressed.
> > It may contain unclassified but sensitive or protectively marked
> > material and should be handled accordingly. Unless you are the named
> > addressee (or authorised to receive it for the addressee) you may
> > not copy or use it, or disclose it to anyone else. If you have
> > received this transmission in error please notify the sender
> > immediately. All traffic may be subject to recording and/or
> > monitoring in accordance with relevant legislation. Any views
> > expressed in this message are those of the individual sender, except
> > where the sender specifies and with authority, states them to be the
> > views of Dorset Council. Dorset Council does not accept service of
> > documents by fax or other electronic means. Virus
> > checking: Whilst all reasonable steps have been taken to ensure that
> > this electronic communication and its attachments whether encoded,
> > encrypted or otherwise supplied are free from computer viruses,
> > Dorset Council accepts no liability in respect of any loss, cost,
> > damage or expense suffered as a result of accessing this message or
> > any of its attachments. For information on how Dorset Council
> > 33> _______________________________________________ Qgis-user
> > mailing list
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>   Roxo
  Roxo
Subject: Digest Footer
Qgis-user mailing list
End of Qgis-user Digest, Vol 159, Issue 46
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
