[Qgis-user] problem with older version
Régis Haubourg regis.haubourg at gmail.com
Mon May 27 02:04:44 PDT 2019
please share screenshot before / after and create an issue in
https://github.com/qgib/QGIS/issues
I suggest you to read carefully the issue template that will help you to be
understood by other contributors around.
I' afraid without more precise description, nobody can help
Best regards
Régis
Le lun. 27 mai 2019 à 10:22, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hi
> I use win 10
> I used to work with  few previous versions of qgis  in the last 3 years
>  few month ago I started using 3.4.5 and set out a  new project with this
> version
> out of several reasons ( problem with synch my layers with the the local
> survey ), I tried to use again 2.18.26 ( las palmas)
> while trying to open the last  project  ( which  I did with 3.4.5 ) I was
> amazed to see that   while opening the project, apart of  5 layer
> /directories out of 32 directories and dozens of sub directories and layers
> the layers that did appear don't have something in common  in relation to
> what didn't appear.
> I hope that I covered enough to get your help
> I don't know what to write more
> thanks
>  boaz
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190527/97c1971a/attachment.html>
