[Qgis-user] Print Composer Filter
Xan Vieiro gallaecia6 at gmail.com
Tue May 28 23:10:03 PDT 2019
Ups...
Hi Karl,
your recipe works fine. Many thanks for the hint!
It will be great if there were a feature filter in the map element at print
composer, so map themes could be reduced.
Kind regards,
Xan V.
O 08:00, Mér., 29 de maio de 2019, Karl Magnus Jönsson <
Karl-Magnus.Jonsson at kristianstad.se> escribiu:
> Hi,
> Good it worked. Posting it to the list as well.
> /Karl-Magnus Jönsson
> 29 maj 2019 kl. 00:05 skrev Xan Vieiro <gallaecia6 at gmail.com>:
> Hi Karl,
> print composer, so map themes could be reduced.
> Kind regards,
> Xan V.
> El mar., 28 may. 2019 a las 11:46, Karl Magnus Jönsson (<
> Karl-Magnus.Jonsson at kristianstad.se>) escribió:
>> Ok. One option is to create a rule based style with a filter for the
>> layer. Then add the style as a named style: In the layers symbology tab ->
>> Style button -> Add… and name it e.g. print style. Then make sure all
>> layers are visible and looks like you want in the layout. Add a map theme
>> e.g print theme and associate the map in the layout with this map theme.
>> Then you can change the style in main window as you wish, alter to default
>> style for the layer and remove the rule based styling, make more named
>> styles and map themes for different purposes.
>> Regards
>> *Karl-Magnus Jönsson*
>> *Från:* Xan Vieiro [mailto:gallaecia6 at gmail.com]
>> *Skickat:* den 28 maj 2019 11:15
>> *Till:* Karl Magnus Jönsson
>> *Ämne:* Re: [Qgis-user] Print Composer Filter
>> Hi Karl,
>> Hi!
>> How do you mean? You do the filtering in the layer properties in the QGIS
>> main window.
>> No, I don't. I just want to keep the whole layer at main window and doing
>> filtering directly at print composer.
>> For atlas there are some more variables or functions available when doing
>> this.
>> Regards,
>> Xan V.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190529/c2de3093/attachment.html>
