[Qgis-user] Problem running on Ubuntu Cosmic
Charlie Davies charliedavi at gmail.com
Wed May 29 04:39:53 PDT 2019
Hi There.
I am having the error while loading:
Couldn't load SIP module.
Python support will be disabled.
  File "", line 1, in
  File "/usr/lib/python3/dist-packages/qgis/__init__.py", line 72, in
    from qgis.PyQt import QtCore
  File "/usr/lib/python3/dist-packages/qgis/PyQt/QtCore.py", line 26, in
    from PyQt5.QtCore import *
ModuleNotFoundError: No module named 'PyQt5.QtCore'
Python version:
3.6.8 (default, Apr  9 2019, 04:59:38)
[GCC 8.3.0]
QGIS version:
3.6.3-Noosa 'Noosa', 0c5774c
Python path:
['/usr/share/qgis/python',
'/home/charlie/.local/share/QGIS/QGIS3/profiles/default/python',
'/home/charlie/.local/share/QGIS/QGIS3/profiles/default/python/plugins',
'/usr/share/qgis/python/plugins', '/usr/lib/python36.zip',
'/usr/lib/python3.6', '/usr/lib/python3.6/lib-dynload',
'/usr/lib/python3/dist-packages']
and
An error occurred during execution of following code:
qgis.utils.uninstallErrorHook()
  File "", line 1, in
NameError: name 'qgis' is not defined
Python version:
[GCC 8.3.0]
QGIS version:
Python path:
I have tried removing and re-installing.
{19-05-29 12:19}[]CharlieThink:~ charlie% pip3 install PyQt5
Requirement already satisfied: PyQt5 in /usr/lib/python3/dist-packages
(5.12.1)
{19-05-29 12:21}[]CharlieThink:~ charlie% sudo apt-get install python3-pip
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3-pip is already the newest version (18.1-5).
0 to upgrade, 0 to newly install, 0 to remove and 21 not to upgrade.
Python == ```Python 3.7.3```
Any one see my issue?
sent from gmail
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190529/f3cb1541/attachment.html>
