[Qgis-user] export to dxf problem
Boaz Bar Ilan
boazprosie at gmail.com
Tue Nov 12 07:20:07 PST 2019
i use Autodesk trueviewer 2020
i tried as you suggested draftsight and its not importing dxf nor it is
free anymore after 31.12.2019
boaz
בתאריך יום ג׳, 12 בנוב׳ 2019 ב-17:00 מאת Nicolas Cadieux <
nicolas.cadieux at archeotec.ca>:
> See below
> Le 12 nov. 2019 à 02:34, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> What happen is that when importing back the dxf file to the qgis it appear
> as x entities and appear with not the right crs and so i see nothing. And
> then in changing again the crs ( to what i saved it at the first place ) i
> see it fine.
> This is normal, the crs is not save in dxf. Is the crs in longitude and
> latitude (degrees) or in meters? If it is in long lat, that may cause
> additional problems. Reproject and save it in QGIS in a local utm zone in
> meter and see what happens in the cad.
> But the sane file on cad is aot seen .
> What CAD are you using? Try DraftSight. It is free in 2D but not
> OpenSource. Did you find a zoom to layer function in the CAD. It is very
> hard to find the lines manually.
> I hope thats cane clear
> Boaz
> בתאריך יום ג׳, 12 בנוב׳ 2019, 09:01, מאת Matthias Kuhn <
> matthias at opengis.ch>:
>> Hi Boaz,
>> what happens if you open the dxf in QGIS again?
>> Matthias
>> On 11/12/19 7:56 AM, Boaz Bar Ilan wrote:
>> hi thanks
>> somehow it doesn't work
>> what I do - I select a layer and do - project >import export >export
>> project to dxf
>> there I save the scale to the scale on my qgis screen
>> and when I m trying to view it with cad viewer it doesn't show nor on my
>> partners autocad
>> as much as I tried to pan it didn't work
>> thanks
>> boaz
>> בתאריך יום ב׳, 11 בנוב׳ 2019 ב-22:35 מאת Nicolas Cadieux <
>>> AutoCAD programs have a tendency to open the file either zoomed out or
>>> zoomed away from our zone of interest. Ex. Your lines are in Canada but
>>> the files open in France. You need to find your data. Zoom in, zoom out or
>>> pan until you find it. Sometimes, you have a function saying « zoom to
>>> layer extent ». If that does not work, try to find your data looking at
>>> coordinates system.
>>> Don’t forget to do a « reply all » so that the user groupe can profit
>>> from the conversation.
>>> Hope this helps
>>> Nicolas
>>> Le 11 nov. 2019 à 15:15, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
>>> What you mean zooning on the data ?
>>> בתאריך יום ב׳, 11 בנוב׳ 2019, 21:20, מאת Nicolas Cadieux <
>>>> Hi,
>>>> Try zooming on the data. It is quite possible that the data it there
>>>> but that the file opens very far away from the data. That is a common
>>>> problem with CADs.
>>>> Nicolas
>>>> On 2019-11-11 8:29 a.m., Boaz Bar Ilan wrote:
>>>> thanks
>>>> I did what you adviced
>>>> succeeded reopen it in qgis
>>>> but failed in the dxf viewer
>>>> boaz
>>>> בתאריך יום ב׳, 11 בנוב׳ 2019 ב-15:18 מאת Nicolas Cadieux <
>>>>> Hi,
>>>>> You can only save a layer file to dxf, not a project file. Try
>>>>> selecting a layer file and saving that. Then reopen in QGIS before testing
>>>>> in other software. Share the layer file and the exact steps followed if
>>>>> that does not work.
>>>>> Nicolas
>>>>> Le 11 nov. 2019 à 08:07, Boaz Bar Ilan <boazprosie at gmail.com> a
>>>>> écrit :
>>>>> hallo
>>>>> im trying to export a project to a dxf
>>>>> as much as I try the file appear empty and nor I and nor other can
>>>>> open it
>>>>> I tried all the options
>>>>> where can I change something so that it will work ?
>>>>> thanks
>>>>> boaz
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191112/6ecb3dea/attachment.html>
