[Qgis-user] Merge does work (at least not as I expect)
Alexandre Neto senhor.neto at gmail.com
Wed Oct 2 10:32:39 PDT 2019
The layer being multilinestring just mean that you can create features with
multi geometries in it. It says nothing about the actual features in it.
A quarta, 2/10/2019, 17:04, <qgis-user at stripfamily.net> escreveu:
> On 10/2/2019 9:41 AM, Alexandre Neto wrote:
> Hi,
> Using your layer directly into merge lines algorithm worked properly on
> QGIS 3.4 in Linux. That is, in the end, I got one single feature that is no
> longer multi. (if I try to go multipart to single part I can't get the
> individual segments).
>  When I merge on the layer, I get a new layer that still reports as
> multi-linestring
> However, it is internally different since now when I export as a gpx file,
> it is a single segment, which was the goal. Curious that it still reports
> the type as MultiLineString.
> Hope it helps,
> Indeed, it solves the problem
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191002/2c329ab1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191002/2c329ab1/attachment-0001.png>
