[Qgis-user] Swamp identification
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed Oct 2 11:45:58 PDT 2019
I see you have been pointed to the semi automatic classification plugin.  Note that Google Earth is not usable for such work unless you simply want to make a visual identification.  Landsat can be used.  You should look at various peer review papers if you want to make a good job.  This is not as simple as it looks.  Also, identifying the correct type of swamp, bog... is one of the most difficult things to do.
Nicolas
> Le 2 oct. 2019 à 08:19, jean Lukusa <lukusam at gmail.com> a écrit :
> Hi all .
> Would you  assist me how to identify swamp areas in a  landsat or googleearth
> Qgis-user mailing list
