[Qgis-user] Profile Tool Plugin installation problem
Andreas Neumann a.neumann at carto.net
Thu Oct 3 03:10:42 PDT 2019
QGIS 2.14 is not supported anymore. I recommend to upgrade to QGIS 3.4
or higher.
However, there are several profile plugins available. You can, e.g. try
to use the VOGIS Profile tool
(http://plugins.qgis.org/plugins/VoGisProfilTool/) or  one of the other
profile plugins.
But it could also be some basic problem on your machine with Python ...
Greetings,
Andreas
On 2019-10-03 11:52, Pallavi Saxena wrote:
> Hi,
> I am working on Qgis 2.14 Essen version. I want to generate cross-section of river/reach using DEM. I found that profile tool is used to do so. When i installed that plugin an error message prompted that the "Plugin is broken. Python said: No module named PyQt.QtCore. Suggest me what to do to install the plugin or any other option to generate crossection.
> Thankyou
> Pallavi
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191003/0d5a1127/attachment.html>
