[Qgis-user] Upsampling TIN
joolek joolek.o at gmail.com
Fri Oct 4 01:46:51 PDT 2019
I am more interested to have a point in between rather than the triangles,
basically interpolate the data twice, to have an extra vertex between the
existing one.
J
On Fri, 4 Oct 2019 at 09:23, Luigi Pirelli <luipir at gmail.com> wrote:
> IMHO tension surface simulation for example can be an application where a
> TIN up sample could be necessary
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Book: Mastering QGIS3 - 3rd Edition
> <https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
> * Hire a team: http://www.qcooperative.net
> On Fri, 4 Oct 2019 at 10:14, b.j.kobben at utwente.nl <b.j.kobben at utwente.nl>
> wrote:
>> The main question is actually: why would you want to do that? You just
>> end up with a larger data structure (more triangles) to show exactly the
>> same surface model. You would not have any more detail, i.e the smaller
>> triangles inside the original large one would have exactly the same azimuth
>> and slope and therefore add no terrain detail...
>> yours,
>> Barend Köbben
>> On 04/10/2019, 09:41, "Qgis-user on behalf of joolek" <
>> qgis-user-bounces at lists.osgeo.org on behalf of joolek.o at gmail.com> wrote:
>> Hi Experts,
>> I've tried so many software's without success.
>> Is it possible to upsample existing TIN? What I mean is for example
>> divide each triangle into two for example. Not interpolation but somehow...
>> subdivide or add more vertices between existing one?
>> Thank you for all your time
>> J
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191004/3c3c8b1e/attachment.html>
