[Qgis-user] QGis 3.8 : Still not possible to export maps in multilayer pdf format ?
Stefan Giese Stefan.Giese at wheregroup.com
Thu Oct 10 05:38:05 PDT 2019
Hi Jürgen,
thanks...good to know!
Stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Where2B Konferenz 2019
12. Dezember 2019 in Bonn
where2b-conference.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 10.10.2019 um 14:35 schrieb Jürgen E. Fischer:
> Hi Stefan,
> On Thu, 10. Oct 2019 at 14:23:51 +0200, Stefan Giese wrote:
>> it will be available from version 3.10.
> if build against GDAL 3.
>> You can test it with the nightly build 3.9 developer versions (use osgeo4W
>> setup)
> Which is using the GDAL 3 nightly, which in turn requires PROJ >=6 (which is
> provided by the proj nightly of 7 in osgeo4w).   PROJ 6 and GDAL 3 are however
> not yet supported by GRASS (see https://github.com/OSGeo/grass/pull/136),
> therefore the "regular" GDAL is still 2…
> Jürgen
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191010/6a5a6db9/attachment.html>
