[Qgis-user] Shape files ParcelPoly export to KML
Jake Baker jbaker at comcomsystems.com
Tue Oct 22 09:56:03 PDT 2019
3.8.3-Zanzibar - Windows10 Pro
I am trying to export a ParcelPoly from an imported shape file to a KML file
and coordinates are showing 0.0 for the longitude
Here is an example of wheat I am seeing:
<MultiGeometry><Polygon><outerBoundaryIs><LinearRing><coordinates>0.0,287456
.028099999 0.0,287455.789099999 0.0,287452.288800001 0.0,287423.078299999
0.0,286281.014600001 0.0,286103.5559 0.0,286169.510899998 0.0,287488.9778
0.0,287480.691599999 0.0,287467.0845
0.0,287456.028099999</coordinates></LinearRing></outerBoundaryIs></Polygon><
/MultiGeometry>
How can I export the imported shapefile ParcelPoly to KML and have both the
longitude and latitude?
Thank you for your help.
Jake Baker | Manager of Operations | ComCom Systems
2420 Enterprise Rd. Suite 207 | Clearwater, FL 33763
Office 727-725-3200 Ext. 222
Support 866-887-9798 Ext. 222
*****HIPAA Confidentiality Notice*****
The documents inside this electronic transmission contain confidential
information belonging to the sender that is legally privileged. This
information is intended only for the use of the individual or entity named
above. The authorized recipient of this information is prohibited from
disclosing this information to any other party and is required to destroy
the information after its stated need has been fulfilled, unless otherwise
required by law. If you are not the intended recipient, you are hereby
notified that any disclosure, copying, distribution, or action taken in
reliance on the contents of these documents is strictly prohibited. If you
received this electronic transmission in error, please notify the sender
immediately to arrange for return.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191022/8605c55f/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191022/8605c55f/attachment.png>
