[Qgis-user] assign a symbol based on property in layer
Matt Boyd mattslists at gmail.com
Wed Oct 23 17:00:28 PDT 2019
Perfect, thanks  Harrissou.
On Thu, Oct 24, 2019 at 10:48 AM DelazJ <delazj at gmail.com> wrote:
> Hi Matt,
> In the vector layer properties, categorized symbology, at the bottom right
> of the dialog, you have an "Advanced" drop-down menu with options like "*Match
> to saved symbols" *or *"Match to symbols from file"* that should help you
> achieve what you want.
> Regards,
> Harrissou
> Le jeu. 24 oct. 2019 à 01:35, Matt Boyd <mattslists at gmail.com> a écrit :
>> Hi QGISers,
>> I've got some shapefiles that have a symbology reference embedded in
>> them. I've also got a set of symbols that have the same name as the
>> specific symbology references. I haven't been able to work out how to get
>> qgis to automatically select the symbology reference. I can manually assign
>> each one and then save that as a qgis style for use later but there are a
>> lot of these and I possibly have other use cases.
>> This would be useful for assigning colours based on geology in surface
>> maps.
>> Any tips?
>> Thanks
>> Matt
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191024/40435c9e/attachment.html>
