[Qgis-user] GeoPackage deadlocks (Andrea Peri)
Jonathan Moules jonathan-lists at lightpear.com
Fri Oct 25 14:18:46 PDT 2019
 > Two processes accessing geopackage on a local computer can run into
the same issue. SQlite is designed for a single user.
Interesting. SQlite can most definitely handle multiple users -
certainly reading, and for writing if it's not over the network, I
expect the processes are breaking one (or more) of the "do this to
corrupt your database" rules.
On 17/10/2019 11:54, Patrick Dunford wrote:
> It's not a network issue and neither is it a Windows issue. Two
> processes accessing geopackage on a local computer can run into the
> same issue. SQlite is designed for a single user. It is very reliable
> when used as designed.
> On 27/09/19 7:13 PM, Paul Wittle wrote:
>> Hi Andrea and Enrico,
>> Thank you for providing an answer even if it was not what I was
>> hoping to hear; it was the conclusion I'd reached myself.
>> Has this issue been considered given the official move from shapefile
>> to geopackage as the default format?
>> My understanding was that shapefiles could be used over a network and
>> whilst multiple people editing was dangerous it did not cause deadlocks.
>> Combined with the issues relating to MapInfo tab files over a network
>> I've got into some hot water over my attempt to get QGIS rolled out
>> in our organisation now. I'm going to have to think carefully about
>> my next steps as it can be difficult to educate large numbers of
>> staff and the two issues mean that people using QGIS incorrectly can
>> cause pretty big issues.
>> To summarise,
>>   - You open a geopackage and save to the network; someone else comes
>> along and opens it in their QGIS and everything looks okay until the
>> PCs deadlock...ICT help calls and data corruption may occur.
>>   - You open a MapInfo tab file from the network and it looks fine
>> (accept that it my draw in a user projection). MapInfo user receive
>> errors but this is unknown to the QGIS user...ICT help calls result.
>> Whilst I'm glad the forums have helped to diagnose both behaviours I
>> would personally say that the issues pose a bit of a threat to
>> software adoption by larger companies and institutions that may be
>> using Windows networks and potentially migrating from MapInfo.
>> In both cases my gut feel is that the best solution might be to look
>> into use detection. If GDAL (I assume) can be improved to detect that
>> either file type is already open then it might be possible to simply
>> ban a second user from opening the file at the same time. This might
>> frustrate some users but most importantly it would make the
>> application safer from an ICT perspective.
>> These are of course just my personal opinion from my particular use
>> case so please don't be offended by them if you disagree but I'd be
>> really happy to hear how others are approaching the issues and/or
>> opposing views?
>> Many thanks,
>> Paul
> Qgis-user mailing list
