[Qgis-user] QGIS 3.10 GeoPDF creation greyed out
Jürgen E. Fischer jef at norbit.de
Mon Oct 28 06:41:53 PDT 2019
Hi Andreas,
On Mon, 28. Oct 2019 at 14:23:38 +0100, Andreas Neumann wrote:
> Oh - that is too bad. Do you have any clue when GRASS will be supporting
> GDAL3?
No, all that I could do I have done in https://github.com/OSGeo/grass/pull/137
and https://github.com/OSGeo/grass/pull/136.
> And packaging a version of QGIS without GRASS is probably not an option
> either? Would probably be an extra burden for you on managing the
> packages ...
GRASS builds fine with GDAL3 and PROJ6 - but I can't tell whether it actually
works.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191028/8c004af1/attachment-0001.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191028/8c004af1/attachment-0001.ksh>
