[Qgis-user] Issus on MacOS
Peter Petrik peter.petrik at lutraconsulting.co.uk
Wed Oct 30 03:11:11 PDT 2019
Hi Julian,
thanks for reporting the issue I have raised
https://github.com/qgis/QGIS/issues/32511 also with a workaround for the
issue. Watch that space for potential official fixes.
You do not need to prepend path with system python any more. QGIS
installation should have all the files/software it needs.
Kind regards,
Peter
On Mon, Oct 28, 2019 at 4:17 PM Julian Bogdani <jbogdani at gmail.com> wrote:
> Hello all,
> I’m using 3.4.12-Madeira in macOS 10.15 (Catalina) and I’m having some
> issues with GRASS tools. It seems to be a PATH issue, since QGIS/GRASS is
> not able to find
> > /usr/local/Cellar/osgeo-grass/7.6.1_5/grass76/etc/lock.
> In fact, I have not installed GRASS using Homebrew, since—if I correctly
> understand—GRASS comes with QGIS installer. Looking at my system setting, I
> have ony one additional path added:
> PREPEND PATH /Library/Frameworks/Python.framework/Versions/3.6/bin:
> By the way, is it still necessary or latest QGIS installer comes with its
> own Python?
> The GRASS7 folder was set to:
> > /Applications/QGIS3.app/CONTENTS/MacOS/grass, which does not exist.
> I changed it manually to
> > /Applications/QGIS3.4.app/Contents/Resources/grass7.
> When I save and close the Options window QGIS crashes, but the value is
> saved.
> Any suggestion?
> Julian Bogdani
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191030/0b0f3f49/attachment.html>
