[Qgis-user] QGIS 3.4.12 python error on open plugins list manager
Borys Jurgiel lists at borysjurgiel.pl
Fri Sep 27 02:02:21 PDT 2019
The debug output doesn't want to help, indeed...
Could you try to start a new fresh user profile? It would eliminate two
possible causes: all the user settings (especially the QGIS3.ini file) and all
user-installed Python stuff from
~/.local/share/QGIS/QGIS3/profiles/default/python
Borys
Dnia piątek, 27 września 2019 09:10:42 CEST Walter Lorenzetti pisze:
> Hi Borys,
> it's strange because Python Console working normally, also current
> plugins installed.
> I haven't many installed plugins, only DBManager and Quickmpaservices..
> Running QGIS by shell, on bootstrap I obtain this:
> Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already
> tracking action "Search QMS" under id 288
> Warning: QVariantMap DBusMenuExporterDBus::getProperties(int, const
> QStringList&) const: Condition failed: action
> and on opening plugins manager window this:
> "<font color=\"red\">Si è verificato un errore durante l'esecuzione
> delle istruzioni
> seguenti:<br><tt>pyplugin_installer.instance().showPluginManagerWhenReady()<
> /tt></font><br><pre><br>traceback.print_exception() failed<br></pre>Versione
> Python:<br><br><br>Versione di
> QGIS:<br>3.4.12-Madeira 'Madeira', 625767347a<br><br>Percorso Python:<br>"
> W
> Il 26/09/19 19:59, Borys Jurgiel ha scritto:
> > Not really, except something wrong happens in Python.
> > The plugin manager window is C++ itself, however, when you click to open
> > it, it calls that Python function from your first error message to fetch
> > Python plugins from the repository. When the plugin list is ready, Python
> > calls back the C++ API to open the window.
> > Apparently something bad happens in Python when it tries to fetch new
> > plugins. Are Python plugins generally work for you (hopefully you had
> > some enabled, at least Processing or DB Manager)? Does the
> > Plugins->Python console seem to work? Another idea is maybe running QGIS
> > from the command line would give some debug messages.
> > Borys
> > Dnia czwartek, 26 września 2019 15:46:12 CEST Walter Lorenzetti pisze:
> >> Hi list,
> >> I'm on QGIS 3.4.12 on Ubuntu desktop, today on opening the list plugins
> >> window manager, I obtain the seguent error:
> >> Any idea about it?
> >> Thanks in adavance.
> >> W
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
