[Qgis-user] Options when loading layers into PostGIS with DBManager
Jorge Gustavo Rocha
jgr at geomaster.pt
Sun Apr 19 02:41:45 PDT 2020
Hi Michael,
An alternative is to use the "Browser panel". I use it to drag layers
from the Layer panel into Postgresql. You don't have to choose any
parameters. It just works.
Regards,
Jorge Gustavo
On 19/04/20 09:42, Michael Dufty wrote:
> Hi,
> I am trying out saving data in PostGIS, and have got stuck on the
> upload “import layer/file” dialog in DB Manager.
> Can anyone recommend a good reference on what options should be selected?
> It seems to fall into a gap between PostGIS documentation and QGIS
> documentation and I can’t find any information on what should be
> selected in what circumstances.
> In particular
> Primary key – should this be ticked and the existing id field
> selected? What happens if it is left unticked?
> Geometry column – is this needed? Objects still seem to have geometry
> if it is left out.
> Create spatial index – this sounds like a good idea, but the one
> youtube tutorial I found (Klas Karlson) he left it unticked and said
> the layer already had everything. Is it needed for some source
> formats and not others eg shapefile vs geopackage?
> Convert field names to lower case doesn’t sound very useful, but I
> presume it is there for a reason, does anyone know the circumstances
> that would be needed?
> Cheers,
> *Michael Dufty*
> *Senior Environmental Engineer*
> *MBS ENVIRONMENTAL**
> *4 Cook Street, West Perth WA 6005
> t: +61 8 9226-3166
> f: +61 8 9226-3177
> e: mdufty at mbsenvironmental.com.au
> <mailto:mdufty at mbsenvironmental.com.au>
> w: www.mbsenvironmental.com.au
> <blocked::http://www.mbsenvironmental.com.au/>
> Disclaimer:
> The information contained in this message is intended for those to
> whom it is addressed. It may contain confidential or privileged
> information and if you are not the intended recipient, you must not
> copy, distribute or take any action in reliance on it. If you received
> this message in error please destroy it and reply to the sender
> immediately or contact Martinick Bosch Sell Pty Ltd. on +61 8 9226
> 3166 immediately. All care has been taken to ensure that this message
> and any attachments are virus free; we do not accept responsibility
> for any virus infections caused by receipt of this message//
> Qgis-user mailing list
Email Signature
Logo <https://www.geomaster.pt>
*Geomaster*
*Jorge Gustavo Rocha* | Software Engineer
*e:*jgr at geomaster.pt | *m:*+351 910 333 888
*g:*41.54094,-8.40490 | *v: *510 906 109
*a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200419/510e3905/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200419/510e3905/attachment-0001.jpg>
