[Qgis-user] [QGIS-Developer] Memory Leak / Slowdown?
Matthias
matthias at opengis.ch
Mon Apr 20 08:20:50 PDT 2020
Hi Peter,
Happy you found a way.
Can you try proposals number 2 and 3 from my previous email? If they do not help, please open a ticket.
Bests
Matthias
> Hi Matthias,
> Thanks to your hints I found a way:
> The script also works if I do not add the Layer to the Project but directly save the Sld-Style. So I can also skip clearing the QgsProject.instance.
> vlayer=QgsVectorLayer (pfad ,sfileOhneExt,"ogr")
> #QgsProject.instance().addMapLayer(vlayer)
> vlayer.saveSldStyle (sldpfad)
> #QgsProject.instance().clear()
> But besides my personal “success”: including the 2 Lines should not lead to rising time /memory consumption or am I wrong?
> Should I make a ticket?
> Peter
> Hi Peter,
> It's possible that a part of the cleanup only happens on the next event loop run.
> Questions / things to try:
> - Do you really need to add them to the project or is a layer without adding it to the project good enough for your purpose?
> - Can you run this in batches of ~100 (or even 1) each and then trigger the next batch on a new event loop invocation, e.g. by using QTimer.singleShot()
> - The easiest thing would be calling QgsApplication.processEvents(), but be warned that using this is known for introducing instabilities, depending on the context in which it is called
> Matthias
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200420/63f751f9/attachment-0001.html>
