[Qgis-user] new Ubuntu-20.04 still not up to date
Matthias Kuhn
matthias at opengis.ch
Thu Apr 23 22:31:37 PDT 2020
Hi Dave,
Concerning Option B.
Use the "Add Shapefile" menu, not "New Shapefile" menu.
The former one adds an existing shapefile to your QGIS project. The
later one creates a new empty file (and hence asks you if you want to
overwrite the existing one with data).
Best regards
Matthias
On 4/24/20 3:27 AM, Dave Kimble wrote:
> With a clean install of Ubuntu-20.04, I downloaded qgis from the
> Ubuntu repository.
> This is qgis-3.10.4-A . During the installation I was asked if I
> wanted my old settings preserved, I said No.
> I get different results depending on how I proceed.
> A. If I open the application and choose the blank project, add New
> Shapefile Layer and navigate to "DCDB.shp" I get "The layer already
> exists, overwrite ?" (which seems wrong for a blank project), answer
> Cancel. The input file DCDB.shp is written to a file size of 100 bytes
> from 9.8 MB. This is exactly the same as the problem I was having
> before, which I eventually gave up on.
> B. If I don't open qgis, but simply double-click on "DCDB.shp", it
> opens qgis and loads the layer, which renders correctly. I can change
> the polygons' colours based on the TENURE field. I can save the
> project and close, but on reopening qgis, my project is not presented.
> If I navigate to the newly created ./gis/Lot11.qgz it opens as a blank
> project with no layers.
> At qgis.org I see that you released qgis-3.12 on 17 April 2020, less
> than a week before Ubuntu-20.04 was due to be released.
> At https://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu ,
> I cannot understand what you mean by "To have newer versions, you have
> to add alternative software repositories, by adding one of the
> deb-lines below to your /etc/apt/sources.list file." There are no deb
> lines below. There are 15 URLs.
> Please help.
> Dave
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200424/7f28bd69/attachment.html>
