[Qgis-user] Qgis-user Digest, Vol 170, Issue 55
Jorge Gustavo Rocha
jgr at geomaster.pt
Sun Apr 26 08:02:09 PDT 2020
Hi Alon,
The file you sent doesn't have any details at all. Please open it with a
text editor and check by yourself.
What kind of details are you expecting? Maybe you have somewhere else
the related information, but it is not on the GPX file. Do you have
images, annotations or something like that that you would like to see in
QGIS?
I don't use GPSLogger. Are you exporting the waypoints? Usually the
information you capture comes as waypoints.
Maybe you can export the same track as KML and have more related
information on the KML file.
I use OSMTracker for Andoid and I'm able to have access images and
annotations I've made on the field.
Best regards,
Jorge
On 26/04/20 11:45, Alon Goldenberg wrote:
> Hi Jorge,
> Thanks for your quick response :)
> With regards to the national_monuments_wgs84.gpx - I get the same as you.
> Since there is so little info in there, I thought it was defective.
> Nevertheless, my file which is quite full of details, loads with an
> empty attribute table. Actually, upon loading, 'waypoints' and
> 'routes' come with no geometry at all, and 'tracks' displays a line by
> with an otherwise empty attribute table. (I need the specific data of
> all waypoints for further processing)
> I enclose (see attached) the GPX file produced by the Android app
> GPSLogger for your reference.
> I wonder if you can solve this riddle for me.
> Thanks for your attention.
> Best,
> Alon
> Message: 1
> Date: Sun, 26 Apr 2020 10:20:25 +0100
> From: Jorge Gustavo Rocha <jgr at geomaster.pt <mailto:jgr at geomaster.pt>>
> To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Fwd: GPS Tools - GPX files are opened with
> black attribute lists
> Message-ID: <5e72848b-d950-6b70-2c79-2b34fabca36f at geomaster.pt
> <mailto:5e72848b-d950-6b70-2c79-2b34fabca36f at geomaster.pt>>
> Content-Type: text/plain; charset="utf-8"
> Hi Alon,
> I've opened the national_monuments_wgs84.gpx in QGIS and only 3
> attributes are showed: name, src and url [1]. If you open the file
> with
> a text editor you will see that's the only data associated with the
> points [2].
> In my QGIS installation, GPX files are being parsed properly.
> Can you confirm that you are able to view these 3 attributes from
> national_monuments_wgs84.gpx?
> Best regards,
> Jorge Gustavo
> [1] https://nextcloud.di.uminho.pt/s/JtKpiA5LbmNZL38
> [2] https://nextcloud.di.uminho.pt/s/R65tQrf2zwRoGAG
> On 26/04/20 08:55, Alon Goldenberg wrote:
> > Hello,
> > I'm using QGIS 3.10.3
> > see more details:
> > The app fails to open GPX files properly - attribute tables are
> blank
> > (or almost blank).
> > I used: GPS Tools > Load GPX File
> > I verified the file on some online tools and it proved OK.
> > I also tried opening qgis_sample_data
> > file: national_monuments_wgs84.gpx - same problem.
> > Any idea on how to resolve this?
> > Thanx,
> > Alon
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
> > Virus-free. www.avg.com <http://www.avg.com>
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Email Signature
> Logo <https://www.geomaster.pt>
> *Geomaster*
> *Jorge Gustavo Rocha* | Software Engineer
> *e:*jgr at geomaster.pt <mailto:jgr at geomaster.pt> | *m:*+351 910 333 888
> *g:*41.54094,-8.40490 | *v: *510 906 109
> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
Email Signature
*Geomaster*
*e:*jgr at geomaster.pt | *m:*+351 910 333 888
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200426/d97c46a5/attachment.html>
