[Qgis-user] R: Importing a raster into a Geopackage
Sebastian Gutwein
bas at rdgland.com
Tue Dec 1 09:17:55 PST 2020
This looks like the same issue you are having.
github.com/qgis/QGIS/issues/38227
According to the documentation linked in the issue you need to set the band
count to 1 otherwise it defaults to 4.
gdal.org/drivers/raster/gpkg.html
I have not tried this to see if it works.
On Tue, Dec 1, 2020 at 11:52 AM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> Looking at it now. I see what you see. I will try a few things.
> Nicolas
> On 2020-12-01 11:42 a.m., Alberto Vavassori wrote:
> Hi Nicolas,
> thank you for the answer. I send the raster that I am interested in.
> Alberto
> *Da:* Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> *Inviato:* martedì 1 dicembre 2020 17:40
> *A:* Alberto Vavassori <alberto.vavassori at polimi.it>
> *Cc:* qgis-user at lists.osgeo.org
> *Oggetto:* Re: [Qgis-user] Importing a raster into a Geopackage
> Hi,
> Send a sample data set if you can't figure it out.
> Nicolas
> On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
> Hi,
> Perhaps this can help: https://gdal.orgdrivers/raster/gpkg.html
> “Various kind of input datasets can be converted to GeoPackage raster :
> · Single band grey level
> · Single band with R,G,B or R,G,B,A color table
> · Two bands: first band with grey level, second band with alpha
> channel
> · Three bands: Red, Green, Blue
> · Four band: Red, Green, Blue, Alpha
> GeoPackage rasters only support Byte data type.”
> My guess is that if the original raster does not correspond to one of the
> categories above, it will be converted to the closest format.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 1 déc. 2020 à 09:58, Alberto Vavassori <alberto.vavassori at polimi.it>
> <alberto.vavassori at polimi.it> a écrit :
> Hello everybody. I have an issue regarding the Geopackage format. I have
> tried to import a singleband raster file (it represents the land cover,
> thus every pixel has a single integer value corresponding to the land cover
> class), but this operation seems to modify the raster characteristics: the
> raster becomes a 4-bands raster and the pixels values change accordingly
> (basically, the original raster is saved in the Geopackage as an RGB
> image). It seems to be a bug of QGIS. I have also tried to use GDAL
> translate through the processing toolbox of QGIS to convert the TIFF file
> to a Geopackage file, but the result is the same.
> Has anybody faced this problem? May anybody suggest a way to work this
> problem out?
> Thank you.
> Alberto
> Qgis-user mailing list
> Nicolas Cadieux
> Nicolas Cadieuxhttps://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/981921cd/attachment.html>
