[Qgis-user] QGIS 3.16 Installation on Linux Mint
Mike Flannigan mflan at mflan.com
Wed Dec 2 04:22:48 PST 2020
Thanks Chris, I really appreciate the response.
Sure sounds like an area that could use some improvement.
I suspect there is a good reason why Linux Mint (LM) 19.3
cannot be called bionic instead of tricia.  So first question
is how do I cross reference names and numbers (i.e. Ubuntu
bionic = 18.04).  I did some looking.  Is LXR needed for that?
I also went into 'Release' and 'InRelease' on that website, but
could not cross reference bionic to 18.04.
Second question is how do I cross reference between Ubuntu and LM?
i.e. LM 19.3 tricia is based on Ubuntu 18.04 bionic.
I'm still looking.  I will report this if I find it.
Mike
On 12/1/20 11:03 PM, chris hermansen wrote:
> If you go look in https://qgis.org/debian/dists/ you will see the
> following Debian and Ubuntu dists supported:
> bionic/  22-Nov-2020 18:36 -
> buster/  23-Nov-2020 05:01 -
> cosmic/  08-Aug-2020 20:57 -
> disco/   08-Aug-2020 20:57 -
> eoan/    24-Oct-2020 12:08 -
> focal/   22-Nov-2020 22:37 -
> groovy/  23-Nov-2020 00:15 -
> jessie/  08-Aug-2020 20:57 -
> precise/ 08-Aug-2020 20:57 -
> stretch/ 08-Aug-2020 20:57 -
> trusty/  08-Aug-2020 20:57 -
> unstable/ 23-Nov-2020 09:05 -
> xenial/  08-Aug-2020 20:57 -
> As far as Ubuntu goes, bionic = 18.04, cosmic = 18.10, disco = 19.04,
> eoan = 19.10, focal = 20.04, groovy = 20.10, xenial = 16.04 and
> precise... wow that's 12.04 which has been unsupported since 2017.
> Well anyway.
> Not to mention the Debian users which have the selection of buster,
> jessie, stretch, trusty and unstable.
> Not to mention the Mint users using Ulyana which is AFAIK based on
> Ubuntu 20.04 (focal)?
> So probably hardcoding it to refer only to the Ubuntu 18.04 / bionic
> distro and thereby also satisfying the Mint folks on tricia would
> cause a lot of surprise to quite a lot of users.
> Also please remember that there are lots of other Ubuntu (and Debian)
> derivative distros that can likely use the appropriate Ubuntu distro.
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201202/9fdbb2b8/attachment.html>
