[Qgis-user] R: Importing a raster into a Geopackage
Alberto Vavassori
alberto.vavassori at polimi.it
Thu Dec 3 00:01:43 PST 2020
Thank you both for the help. Now it seems to work for me, too!
Alberto
Da: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Inviato: giovedì 3 dicembre 2020 00:53
A: Alberto Vavassori <alberto.vavassori at polimi.it>
Cc: qgis-user at lists.osgeo.org
Oggetto: Re: [Qgis-user] Importing a raster into a Geopackage
Just to close this thread, this is the answer I got from Even Rouault on the gdal dev mailing list.
On mercredi 2 décembre 2020 15:16:44 CET Nicolas Cadieux wrote:
This follows a discussion in the qgis-user mailing list. We are using
gdal_translate (and QGIS "export as") on a 8bit unsigned single band
tiff to a .gpkg. When using no -ot switch or when using -ot Byte, this
results in a 4 band .gpkg raster with the wrong values. (Values in band
1 to 3 are similar but off the mark). Band 4 is set at 255 as expected.
Looks like some type of compression is going on in the band 1 to 3).
When saving using the -ot Int16 or Float32 switch, all is well and the
result has one band with the correct values.
ex: gdal_translate -ot Int16 -of GPKG "E:/Users/Nicolas/Google Drive
Nicolas/Partage_temporaire/qgis/int16.gpkg" "E:/Users/Nicolas/Google
Drive Nicolas/Partage_temporaire/qgis/int16.gpkg"
Is this a possible problem with the driver or is the problem sitting 18
inches in front of the screen? Problem similar on a Mac running QGIS
3.10.1-A with GDAL 3.0.2 and QGIS3.16 on Windows running GDAL 3.1.4.
Test files are found here:
https://drive.google.com/drive/folders/1fMl9odowUFFRQFK61rTxgHeom_D8ymN6?usp
=sharing
The answer is there:
https://gdal.org/drivers/raster/gpkg.html#tile-formats
For Byte input (that isn't recognized as to be used by the tiled gridded
coverage data), the default tile format will use JPEG lossy compression for
tiles with a fully opaque channel.
-co TILE_FORMAT=PNG will use lossless compression
GeoPackage raster aim was initially for visualisation purposes, hence this
default. The more analytic side was a later addition to the format, and
actually an extension
Even
http://www.spatialys.com<http://www.spatialys.com/>
Le 1 déc. 2020 à 09:58, Alberto Vavassori <alberto.vavassori at polimi.it<mailto:alberto.vavassori at polimi.it>> a écrit :
Hello everybody. I have an issue regarding the Geopackage format. I have tried to import a singleband raster file (it represents the land cover, thus every pixel has a single integer value corresponding to the land cover class), but this operation seems to modify the raster characteristics: the raster becomes a 4-bands raster and the pixels values change accordingly (basically, the original raster is saved in the Geopackage as an RGB image). It seems to be a bug of QGIS. I have also tried to use GDAL translate through the processing toolbox of QGIS to convert the TIFF file to a Geopackage file, but the result is the same.
Has anybody faced this problem? May anybody suggest a way to work this problem out?
Thank you.
Alberto
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201203/226687a6/attachment-0001.html>
