[Qgis-user] QGIS 3.16 Installation on Linux Mint
Roderick Anderson raanders42 at gmail.com
Fri Dec 4 17:03:04 PST 2020
On 12/3/20 6:23 AM, Mike Flannigan wrote:
> Thanks.  I am using the Flatpak ver 3.10.12 out of the LM
> Software Manager.  I've been using it for quite a while and
> it works great.  The problem is, my Update Manager keeps
> upgrading QGIS (most recently to 3.16), but I cannot find
> it or run it.  You can read the details here:
> https://forums.linuxmint.com/viewtopic.php?f=47&t=335784
No Flatpak expert here but I'd guess the version (executable) installed
using flatpak falls lower in the path than the regular package manager does.
> Synaptic package manager says I have 3.16 installed:
> http://www.mflan.com/temp/synaptic.jpg
> but I have looked hard and can't find it.
> 'sudo apt-get purge QGIS' does not get rid of 3.16.
> Software Manager says I have 3.10 Flatpak installed, but
> not the regular 3.16.1+28bionic that is also listed in
> the Software Manager.  If I try to install 3.16.1+28bionic
> it fails immediately on package dependency problems.
I had tried installing using Synaptic and got 2.16 so I uninstalled it
and used Flatpac.  Just checked and see 2.18 offered via the package
manager.
> So my system keeps updating, but I am left with only 3.10 to run.
> Perhaps Flatpak 3.16 will come along eventually.  Or maybe
> I will uninstall 3.16 from Synaptic package manager and then
> try to reinstall 3.16 from Software Manager or from the
> QGIS website.
> If I did the Flatpak on this site
> https://www.qgis.org/en/site/forusers/alldownloads.html#flatpak
> what version would I get?
I got 3.16.1-Hannover using the instructions.
Here is my menu command line
/usr/bin/flatpak run --branch=stable --arch=x86_64 --command=qgis
--file-forwarding org.qgis.qgis @@ %F @@
Good luck,
Rod
> Mike
> On 12/3/20 2:01 AM, qgis-user-request at lists.osgeo.org wrote:
>> Sorry for the top post but I have already deleted all the previous posts
>> in this thread.  Hopefully my half following of the thread is correct
>> and the OP is having problems installing QGIS.
>> How about using flatpak to install.  I did on Linux Mint 19.3.  Found
>> the instructions at:
