[Qgis-user] Trying to use the v.split to break down a Polyline into 2 point segment to add feet label.
Charles Dixon-Paver charles at kartoza.com
Fri Dec 11 08:00:45 PST 2020
Make sure you are running qgis-bin-g7.exe
If it is not in your C:\OSGeo4W64\bin then install QGIS using the OSGeo4W
installer and use the "express" installation option, making sure to check
the GRASS box
On Fri, 11 Dec 2020 at 17:46, Wolf, Mark <Mark.Wolf at citynet.net> wrote:
> *This algorithm cannot be run :-( *
> The specified GRASS 7 folder "C:\PROGRA~1\QGIS3~1.16\bin\bin" does not
> contain a valid set of GRASS 7 modules. Please, go to the Processing
> settings dialog, and check that the GRASS 7 folder is correctly configured
> Can someone navigate me in the right direction here?
> Mark
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201211/a83798af/attachment.html>
