[Qgis-user] Editing my map
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Dec 15 08:11:02 PST 2020
"Is there a better way to do this?"
Yes, try Vector/geoprocessing tools/clip.  Select the US, in the
countries files, select "district" as input layer in the clip tool GUI
and the country file as the Ovelay layer (use selected features only if
you have pre-selected the US).
Good luck
Nicolas
On 2020-12-15 8:22 a.m., Kenny Nagano wrote:
> Here are the 3 layer files I used in this project. I did make some
> progress on my own as you can see the final product on test3.kml. I
> did this by manually deleting every "point" In edit mode I selected
> points and then used the delete button. Sometimes I would delete
> points within the US and then re-create the shape. Is there a better
> way to do this? If I want an exact custom map with the US as an
> outline is there a way to accomplish this? Maybe import a file with US
> longitudes and latitudes?
> On Mon, Dec 14, 2020 at 4:02 PM Nicolas Cadieux
> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>> wrote:
>     Hi Kenny,
>     You have only sent the qgis project and not the files that the
>     project opens.  You must send all the files if you want us to look
>     at the project.
>     Cheers
>     Nicolas
>     On 2020-12-14 9:29 a.m., Kenny Nagano wrote:
>>     I have attached a qgis file that I am trying to edit down. I only
>>     want a custom map of the US. I have clipped the vectors that
>>     don't contain the US but anything that has the part of the US I
>>     can not delete/cut out. The end goal is to have a map of the US
>>     with custom districts. I have tried all "Select by features, by
>>     polygon, by freehand" and not had any luck. Any advice would be
>>     greatly appreciated.
>>     _______________________________________________
>>     Qgis-user mailing list
>>     Qgis-user at lists.osgeo.org  <mailto:Qgis-user at lists.osgeo.org>
>>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user  <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user  <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     Nicolas Cadieux
>     https://gitlab.com/njacadieux  <https://gitlab.com/njacadieux>
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201215/69589bc6/attachment.html>
