[Qgis-user] editing a layer in excel
Marin Mirosevic
marin.mirosevic at bouvet.no
Wed Dec 16 08:59:15 PST 2020
(I am quite new in Qgis so please ecuse me if something doesn't "compute" in my explanations/Question)
If workflow could be confirmed that this is ok the way Columns can be updated/Joined?
1. Export as excel from a Layer (from Qgis)
2. Edit Excel file (edists are backpropagated to Qgis table)
3. Right click on Polygon/Point (holding attributes) - Properties -Joins (select excel table which lies as table in Qgis )-select Join and Target field(which have to be the same)- select Joined fields(to bring in changed columns in Excel itself)
4. Column(s) added
Also could Parameters/Columns - be just updated with new values (maybe better then join as new parameter/column)? IF yes how ( didn't found an option)
Legend
1. excel file/table (produced by export)
2. Layer from which (excel ) was initially exported
[cid:image002.jpg at 01D6D3D5.29D02550]
With regards/ Vennlig hilsen
Marin Mirosevic
Consultant
Mobil +47 909 67 511
marin.mirosevic at bouvet.no<mailto:marin.mirosevic at bouvet.no>
Bouvet Norge AS
bouvet.no<http://www.bouvet.no/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201216/36651592/attachment-0001.html>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201216/36651592/attachment-0001.jpg>
