[Qgis-user] Unable to install Scipy Point Clustering Plugin
Nicolas Cadieux njacadieux.gitlab at gmail.com
Sun Dec 20 08:02:47 PST 2020
Looks like the plugin is having difficulty loading the NUMPY_MKL library.  I would contact the maker of the plugin or find another plugin that does the same thing but using a new version of QGIS.  QGIS 2.18 is quite old and not maintained.  The pluGin is also flagged as experimental.  I would start new email asking for help on what you need to do and ask how to do it.
You could try installing version 0.1 of the plugin.
https://plugins.qgis.org/plugins/ScipyPointClustering/
If you are good in python, you could alway try to figure out why the library is not available add try to install it yourself.  Looks like as import problem so that would indicate Numpy  mkl is not installed.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 19 déc. 2020 à 22:20, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
> Nicole,
> Thanks for the reply. I loaded the plugin in the directory. But, still it is not working.  The path of my plugin directory is C:\Users\username\.qgis2\python\plugins.It is highlighted in red and says that the plugin is broken. Hence, I  tried loading the plugin through url hoping that, that will fix the problem. Even that was giving error as mentioned in my previous email. Regards.
> <image.png>
>> On Sat, Dec 19, 2020 at 7:29 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> You should be able to find it in the normal QGIS plugin repository.  No need to point it elsewhere.  If not, you will find it here.
>> https://plugins.qgis.org/plugins/user/spatialvision/admin
>> Just downloaded it and save it in your plugin directory.
>> Nicolas Cadieux
>>>> Le 19 déc. 2020 à 20:16, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
>>> Hello,
>>> My work requires me to use QGIS 2.18.x. Hence, I downloaded QGIS2.18.28. I am trying to install "Scipy Point Clustering" plugin. I have entered the following details and URL in the Repository details .When I click OK, I am getting the following error. Can anyone please help me?
>>> Regards.
>>> <image.png>
>>> <image.png>
>>> <image.png>
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201220/efd8f951/attachment.html>
