[Qgis-user] QGIS 3.xx not starting
Ujaval Gandhi ujaval at spatialthoughts.com
Sun Dec 20 21:35:38 PST 2020
One of the original suggestions was to disable / uninstall your anti-virus
and try launching qgis. Did you try that? From your description it looks
like Quickheal might be interfering with qgis. Qgis has other dependencies
on python, qt etc so merely allowing qgis may not be enough.
Ujaval Gandhi
Spatial Thoughts
On Mon, Dec 21, 2020, 9:41 AM K R Mayani <krmayani.procivil at gmail.com>
wrote:
> As one suggestion came from other source, I have tried opening QGIS with
> firewall off. So I tried to add .exes of python, qgis ltr, qgis in allowed
> program in QuickHeal, as its installed and managed firewall, but did not
> start.
> So that strike me another idea. And I started the program in safe boot
> mode with network  in windows 10. Surprisingly the program ran normally
> without crashing.
> So can anyone give me any idea, what went wrong in normal boot mode?
> Because in safe boot, OS does not allow to connect through wifi and I, had
> to, mostly work with wifi.
> On Tue, Dec 8, 2020, 7:32 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> wrote:
>> Hi,
>> Just a bunch of ideas...
>> Did you have a working version before or is this a first time QGIS
>> installation?  You have 2 choices of installers on Windows, I would try
>> with the second installer after removing the first version.  Reboot the
>> computer after the installation.  Try Disabling your antivirus or adware
>> software you could have when installing or starting QGIS, make sure your
>> Windows and drivers are up to date.  Do you have a second version of Python
>> on your computer, or a software like ESRI that as it’s own version of
>> Python? Perhaps there is a conflict between your QGIS python and the
>> default python distribution?  If this is not a new install, would you have
>> a problématique python plugin  in the plugin directory? Perhaps try
>> removing those...  Would you have weird character in your user directory
>> like spaces or accents like “é”?
>> Nicolas Cadieux
>> https://gitlab.com/njacadieux
>> Le 8 déc. 2020 à 07:07, K R Mayani <krmayani.procivil at gmail.com> a
>> écrit :
>> Hi,
>> I am using QGIS 3.14.1 on my Laptop. I am having trouble with the
>> software about its starting. After setting up python screen, it does not
>> starts. I have also tried "run as administrator" but still the problem
>> persists. With v3.10 and v3.14.1, the same problem is there. I have
>> installed software again with "Run as Administrator" but the issue is not
>> solved.
>> .NET 4.8 already installed.
>> osbuild: 19042.630
>> OS: Windows 10, home
>> Processor:AMDRyzen 5 3550H with Radeon Vega Mobile Gfx 2.10 GHz
>> RAM: 8.00 GB
>> crash: https://pastebin.com/5Tk75LTu
>> Which version should support my system rig?
>> Please help me with my trouble. Or suggest to me the steps.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201221/0ee8aacd/attachment.html>
