[Qgis-user] Meta Search on Mac
Tom Kralidis tomkralidis at gmail.com
Mon Dec 28 10:44:10 PST 2020
Hi: reverting that change will introduce the axis order problems that
the original fix
attempted to solve:
- urn:ogc:def:crs:EPSG::4326 is a CRS whose coordinates must be
represented with a yx axisorder
- urn:ogc:def:crs:OGC:1.3:CRS84 is a CRS whose coordinates must be
represented with an xy axisorder
Having said this, can someone open an issue on GitHub? I have a fix
queued which I will then apply as a PR for testing.
Thanks
..Tom
On Mon, Dec 28, 2020 at 8:21 AM Andrea Giudiceandrea
<andreaerdna at libero.it> wrote:
> Andrea Giudiceandrea wrote
> > It seems the issue is due to the fact that the MetaSearch client sends the
> > bounding box crs as "urn:ogc:def:crs:OGC:1.3:CRS84" in the query, and such
> > string is not recognised by most of those servers.
> > Maybe there is a widely accepted crs string to use?
> Hi again,
> I've found that "urn:ogc:def:crs:EPSG::4326" (instead of
> "urn:ogc:def:crs:OGC:1.3:CRS84") is recognised by all the default CSW
> servers (except two not working at all).
> So I could submit a PR to fix this, unless someone has a better approach.
> Aside from this issue, the two not working default services are:
> UK Location Catalogue Publishing Service
> http://csw.data.gov.uk/geonetwork/srv/en/csw
> and
> UNEP GRID-Geneva Metadata Catalog
> http://geonetwork.grid.unep.ch:8080/geonetwork/srv/eng/csw
> Does anybody know the new address of these services?
> Regards.
> Andrea
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
