[Qgis-user] Converting QGIS map to Kmz/kml
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed Dec 30 18:46:30 PST 2020
To my knowledge no. You could save the files in a geopackage along with the project file. Geopackage can take many raster vector layers and QGIS was the option to save the project file in a geopackage. That would give you one file but not in the KLM or kmz format.
The alternative is to save everything thing in a folder with the QGIS project file. You could compress this folder in a zip if you want just one file if that is the goal (but it would need to be decompress to be read by QGIS.)
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 30 déc. 2020 à 20:34, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
> Hello,
> I have a qgis map with about 8 layers. I know how to export each layer to a kmz/kml. But, Is there a tool that can export the entire map to a single kmz/kml without loosing the symbology? Also, Is it possible to produce a kmz such that the layers appear in the same order that they appear in the qgis map?
> Regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201230/e12eab49/attachment.html>
