[Qgis-user] Plugin Slicer
Christine
geo.guide at web.de
Sat Feb 1 04:25:41 PST 2020
dear Everton,
checked the plugins in my *QGIS 3.10* installations and may confirm, that a
SLICER plugin is not available via the plugin manager. Found also
https://plugins.qgis.org/plugins/Slicer/
<https://plugins.qgis.org/plugins/Slicer/> in the QGIS Plugin repository,
telling explicitly that the SLICER plugin was created for QGIS version 2.
So it seems you have to *install a QGIS verson 2* if you want to use the
SLICER plugin.
Principally it is possible to have several versions of QGIS installed on the
same machine. But I have actually experienced problems with the
geoprocessing of QGIS 2 after having installed also QGIS 3. May somebody
else give an advice for that ?
Nicolas Cadieux wrote
> ... need to use the SLICER plugin but I did not find it in the version I
> installed (3.10.0) I found D.E.M. slicer that is very different!
> Is there a solution to download the original SLICER version 2.14 in Qgis
> 3.10?
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
