[Qgis-user] Error after saving my script
Håvard Tveite
havard.tveite at nmbu.no
Sat Jan 4 11:10:21 PST 2020
Hi Giacomo,
The error message indicates that you have removed (or masked
away) the "name()" function when modifying the scipt.
If you would like to get more help, you will need to show
us your script.
Håvard
On 01.01.2020 18:19, Giacomo Fontanelli wrote:
> Dear forum
> I slightly modified the processing-script called RandomPointsPolygons.py
> to make my own script and I copied it in
> /home/giacomo/.local/share/QGIS/QGIS3/profiles/default/processing/scripts.
> but when I launch QGIS 3.10 I get this error
> NotImplementedError: QgsProcessingAlgorithm.name() is abstract and must
> be overridden
> Traceback (most recent call last):
> File "/usr/share/qgis/python/plugins/processing/script/ScriptUtils.py",
> line 68, in loadAlgorithm
> alg = algfactory.instances.pop().createInstance()
> IndexError: pop from empty list
> During handling of the above exception, another exception occurred:
> be overridden
> Versione Python: 3.7.3 (default, Oct 7 2019, 12:56:13) [GCC 8.3.0]
> Versione di QGIS: 3.10.1-A Coruña A Coruña, ef24c526da
> Percorso Python:
> /home/giacomo/.local/share/QGIS/QGIS3/profiles/default/python
> /home/giacomo/.local/share/QGIS/QGIS3/profiles/default/python/plugins
> /usr/lib/x86_64-linux-gnu/otb/python
> /usr/lib/python37.zip
> /usr/lib/python3.7
> /usr/lib/python3.7/lib-dynload
> /usr/local/lib/python3.7/dist-packages
> /usr/lib/python3/dist-packages
> /usr/lib/python3/dist-packages/IPython/extensions
> Any help please?
