[Qgis-user] Polygonize - No result
Luigi Pirelli
luipir at gmail.com
Tue Jan 7 01:08:46 PST 2020
do you have python_gdal installed and/or check that gdal_polygonize.py is
available... a osgeo4w packaging problem can result in
associate gdal_polygonize.py to a interpreter. In this case, just link or
copy/remane gdal_polygonize.py as gdal_polygonize
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
* Hire a team: http://www.qcooperative.net
On Sun, 5 Jan 2020 at 21:43, Lene Fischer <lfi at ign.ku.dk> wrote:
> Hi
> I´m trying to run Vector to raster (polygonize)
> Suspect it´s the path to GDAL.
> I get this error message
> QGIS version: 3.10.1-A Coruña
> QGIS code revision: ef24c526da
> Qt version: 5.11.2
> GDAL version: 3.0.2
> GEOS version: 3.8.0-CAPI-1.13.1
> PROJ version: Rel. 6.2.1, November 1st, 2019
> Processing algorithm…
> Algorithm 'Polygonize (raster to vector)' starting…
> Input parameters:
> { 'BAND' : 1, 'EIGHT_CONNECTEDNESS' : False, 'EXTRA' : '', 'FIELD' : 'DN',
> 'INPUT' : 'C:/gis/nysted_raster/1_7m.tif', 'OUTPUT' : 'TEMPORARY_OUTPUT' }
> GDAL command:
> python3 -m gdal_polygonize C:\gis\nysted_raster\1_7m.tif
> C:/gis/temp/processing_dc13c7a2a0cf4d22aef37dcd462534db/e5db8073dc414a989e176ea591f28c1c/OUTPUT.gpkg
> -b 1 -f "GPKG" OUTPUT DN
> GDAL command output:
> '\\a00143.science.domain\dlt265\Documents'
> CMD.EXE was started with the above path as the current directory.
> UNC paths are not supported. Defaulting to Windows directory.
> C:\PROGRA~1\QGIS3~1.10\bin\python3.exe: No module named gdal_polygonize
> Execution completed in 0.33 seconds
> Results:
> {'OUTPUT':
> 'C:/gis/temp/processing_dc13c7a2a0cf4d22aef37dcd462534db/e5db8073dc414a989e176ea591f28c1c/OUTPUT.gpkg'}
> Loading resulting layers
> The following layers were not correctly
> generated.<ul><li>C:/gis/temp/processing_dc13c7a2a0cf4d22aef37dcd462534db/e5db8073dc414a989e176ea591f28c1c/OUTPUT.gpkg</li></ul>You
> can check the 'Log Messages Panel' in QGIS main window to find more
> information about the execution of the algorithm.
> Regards
> Lene Fischer
> Associate Professor
> University of Copenhagen
> Department of Geoscience and Natural Resource Management
> Forest and Landscape College
> Nødebovej 77a
> 3480 Fredensborg
> Denmark
> MOB +45 40115084
> lfi at ign.ku.dk
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200107/ef34289d/attachment.html>
